PTO Shaft B2601
samjr66
Gastonia NC
Anyone ever replaced the pto stub shaft on a 2601? Mine snapped off when the drive shaft came apart. Dealer wants me to bring tractor with tiller still attached before they do anything to see what happened as far as warranty. I figured why bother, they are going to deny it. New shaft is $316. Does not seem like it would be a problem , but I am not sure . Wanted to see if anyone here knows if there are any surprises.
SidecarFlip
Banned
561
The surprise is, you have to pull the back cover off and drain all the fluid plus you'll most likely have to replace the seal.
9,196
The reason the dealer wants to see it is to determine if the root cause.
Did the PTO joint go out breaking the PTO shaft
Or did the PTO shaft go out breaking the PTO joint?
2 different scenarios that end up with the same end result. ;)
