PTO problems
USMC8999
B7100
Jul 26, 2023
Oklahoma
While bush hogging the shaft attached to my hog bent and before I could shut down my machine it broke my rear bearing/pto shaft housing cover from the tractor and pulled the pto shaft out. I was able to recover the pto shaft with the gear attached but I know I have lost a part or 2 . My tractor is a 1984 B7100. Does anyone have any idea where I can find a replacement housing cover? Does anyone have a diagram of the rear pto shaft area so i can see what I am missing?
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
642
256
Herald Calif.
I often mention you to folks needing parts, but I thought you had mostly "L" parts! Sorry about that.
I always appreciate that. I mostly have older L Series stuff. I do have a little bit of old B series but not much. This is one I happen to have. Mountain Man is the man for B series parts. He has helped me out as well.
1,411
View attachment 108110 View attachment 108111 While bush hogging the shaft attached to my hog bent and before I could shut down my machine it broke my rear bearing/pto shaft housing cover from the tractor and pulled the pto shaft out. I was able to recover the pto shaft with the gear attached but I know I have lost a part or 2 . My tractor is a 1984 B7100. Does anyone have any idea where I can find a replacement housing cover? Does anyone have a diagram of the rear pto shaft area so i can see what I am missing?
That had to be an exciting event!
I am glad you are okay.
