Hallo Friends,
I broke my baby !
I have hooked up a water pump to the PTO and slipped from the icy clutch pedal. There was a bad sound from the kick at the back, but then sound normal. So I thougt it was just the pump and the chain. But after I stopped pumping, I saw oil flowing in a thin line out of the PTO. I parked the traktor at it's place and put a Bucket under it. One day later it was filled with 3-4 Liter of oil. I moved the tractor into the outbuilding and open the PTO-cover.
The oil-sealing was broken and the bearings sound bad. And the oil itself was frightening. So many metal parts... and used-up color.
Here are the Pic's:
The Waterpump:
The PTO Gear:
The Oil:
By the way, is it a oil-filter at the right top. And if, has somebody the partnumber?
I will keep you informed...
carl
I broke my baby !
Here are the Pic's:
The Waterpump:
The PTO Gear:
The Oil:
carl
