PTO not disengageing
FOXHAVEN
The PTO on my L2501 is cable operated and does not disengage most of the time. I can sometimes wiggle the cable just under the lever and it will disengage other times I have to cycle the throttle and depress the clutch repeatedly to get it to disengage.
Could use suggestions on adjustment or spring replacement, anything you have been successful with resolving this kind of problem.
Thanks
Mak65
L2501 HST
Apr 25, 2019
122
90
TX
Get some spray lubricant with straw nozzle and spray it into the cable housing where the cable enters. Spray both ends. With the engine off move the lever back and forth from engaged to disengaged multiple times. Should free it up. Common problem on this model. Worked for me. I spray mine frequently and it hasn’t occurred again.
