PTO Issue
appleguy
L275Dt, front mount snow blower, bean 3 pt sprayer, 6' bush hog mower
Dec 18, 2009
9
Oamk, WA
I have a L 275DT. Ever since I bought it 8 years ago the only way to engage the PTO is shut off engine, engage PTO and then re-start. This can't be right and has to be hard on starter and engine. PTO will not dis-engage when clutch pedal is depressed. I fear something is dis-connected inside transmission. Any thoughts??
appleguy
Dec 18, 2009
9
Oamk, WA
Thanks...as in the clutch pedal linkage? I have never had a problem dis-engaging the clutch to shift. There appears to be a cable on the left side of the shift housing that is on top of the transmission beneath the steering column. Any idea what it controls?? It never moves when de-clutching or shifting transmission.
Milo Holroyd
1979 L245DT w/1700 FEL, 2003 L3130 HST,w/ LA723 loader,,and L2174A snowblower
I was referring to the "main" clutch adjustment. On my (1982 L245DT), that's the only clutch there is.
I'm not familiar with your model. Perhaps there is a "seperate" clutch for the PTO, that works in conjunction with the main clutch?
Hopefully Ed or Vic will have an answer.
Milo:confused:
appleguy
Dec 18, 2009
9
Oamk, WA
Adjusted clutch linkage today and viola!! finally can disengage PTO. Cable I referred to goes from the 2 speed linkage to the sheetmetal housing that covers the transmission and which the shifting levers go through. Can't figure out it's function. Thanks for the help.
