PTO gears for B7001D
The Chief
Kubota B7001 (grey market), RS1200 tiller, V1 FEL, Sears 16.5 hp garden tractor
Nov 6, 2010
Sundre, Alberta
I am in need of the drive and driven PTO gears as well as a bushing and output shaft seal. I can get gears for a B7100D from Kubota but they think my tractor is too old for those gears to fit, Any suggestions?
The Chief
Nov 6, 2010
Sundre, Alberta
Sorry, I didn't list my model No. I have a grey market 7001 but supposedly most parts for a 7100 will fit but not sure in this case whether the gears will fit.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
Hi there chief,
I think you will struggle to get any internal gear parts from a B7100 into a B7001 back end, maybe the odd part here and there.
they may be very similar in respect to casings etc, and body work, even the same engine but, there are a lot of different parts internally and externally.
and that includes inside the rear end.
The b7100 and b7001 are not the same machine, and as far as transmission etc goes, the 7001 is closer to a B7000.
I have been downthis route and had both rear end open side by side , the differences are all over the place, even the pto shafts and gears are diffenent.
but, the pto output shaft oil seal is the same item on both 7100 and 7001, as i have ordered the same part for both of my machines, as are the axle shaft oil seals etc.
sorry to put the dampers on it, but you need to be very carefull when swapping rear end parts between 7001/7100 etc, same applies to 6001/6100 etc.
they look the same machines but they are not, but there is nothing lost in trying and you may just find some parts that you can retro fit.
thanks
rob
