PTO CLUTCH
bbolding
Same Dorado 85
Apr 27, 2022
Goulburn
I HAVE A SAME DORADO 85
WHEN IM USING THE PTO FOR SLASHING IT WILL DISENGAGE WHEN IM IN LONG GRASS.
DO I NEED A NEW CLUTCH OR IS THERE ANOTHER PROBLEM
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
I had to look up to see what a Same Dorado 85 was and if my research is correct it is an Italian made tractor.
4,252
Like others, first I’ve heard of a SAME tractor. RalphVa asked a good question. If there’s a clutch on the PTO shaft and it’s slipping it either needs adjusting or replacing. If it has a clutch on the PTO shaft, I would put witness marks on both sides of the clutch and recheck their alignment next time it does it. If the marks aren’t still aligned you know the clutch is slipping. You’ll need to follow the manufacturer instructions to adjust the clutch.
If there isn’t a clutch on the PTO shaft I have no clue.
