Pro's & cons of alternate wheel/tyre configs on kubotas.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
9
Leafy England....
Hi all,
not been on here for a while , been to busy building a hydraulic tipping trailer 7" x 4" , also refubing my Recent purchase of a nice little L225.
Anwway to the subject matter, my L225 is fitted with the factory 9.5 x 24 ags on the rear with 20 x 8 x 10 turfs on the front.
As per most tractors various wheel/tyre configs are listed depending on usage etc.
i'm interested in your thoughts on ags options to be honest, on my L225 i can fit the 13.6 x 16 ags from my B8200 as they are a stated option but what are the pros and cons over the 9.5 x 24,s on at present.
wider is better for me but i'll be loosing some ground clearance etc any thoughts.
rob
2,671
what is the primary purpose of the L225? And looking at the info and specs, it is a 2wd model? It would have to be, otherwise it would be L225DT.
I would go with the ag bar setup....unless all you are going to do is cut grass.
you statement:
would drive my answer!
