Hi folks!
New in here, good to be with Pro's.
Im asking a bit help with my Kubota Z400 engine. I bought it as "almost scrab". It has stand like 2 years, but the seller told it was in running condition before that, maybe had some valve problems but did run.
Now i've tried to get it running, but havent got it yet...
I've got diesel from pump, injectors and nozzlez cleaned (not tested tho).
Glow plugs are dead, but tried with really careful amount of start spray. It just caughts couple times, but when start gas burns off, its all dead end. Just keeps starting.
Today i got an old pressure test for diesel, going to test it tomorrow if i have time, and soon going to take injectors to diesel workshop. BUT, now I'd need some help with injection pump. Can it be opened and repaired by self?
I think there is going to be something wrong in that pump, because when shutdown is pulled all the way to STOP, Injection pump starts to give fuel. Before that nothing. So someone has opened it for sure and now it needs to be remaked.
Any guides for Diesel Kiki 2-port diesel injection pump reconstruction / maintenance?
Anyt other hints that would help me to get the motor running?
Done so far:
- Adjustet valves
- Cleaned all fuel lines and tank + new filter
- Changed oils
- Cleaned injectors, and took all air of from fuel system
- Noticed that STOP- lever works the opposite and determined its because the injection pump (am i right?)
- Noticed that glow plugs are both dead
- Borrowed pressure tester for cylinder pressure test.
Best regards
Tuomo, Finland
Done so far:
- Adjustet valves
- Changed oils
Best regards
Tuomo, Finland
