Hi guys! First time caller, long time listener...
...So I bought a brand new L2501, along with a brush cutter, grapple bucket and box blade.
I already had to send the brush cutter back, as it puked out all its oil before I ever even used it.
I've used the grapple most of all, and the tractor now has about 25 hours on it. I had parked it in my garage after using the grapple, and didn't get a chance to use the machine for about 2 weeks.
The other day I wanted to move it out of the way, but the battery was dead, which seemed odd for it having been just a couple weeks sitting. I charged the battery, then wanted to use the tractor and grapple today, and when I tried to open the grapple jaws, they would not. Everything on the tractor seem to work okay. Upon inspection, I found that the grapple control is direct wired to the battery with an in-line fuse. I checked the fuse and it was blown.
I changed the fuse and started up. The grapple wouldn't open still, but now the loader will barely function. I pulled the fuse to look at the connection, and even with the tractor off, when the fuse makes contact it makes a spark.
I believe that the "close" function is stuck that way, which, since it is hard wired to the battery, might be the cause of the dead battery. Is there a solenoid somewhere that works the open/close function of the grapple?
I read the manual for the tractor, and didn't get any literature on the 3rd function valve, but I'm not really sure where to start.
I should mention that all attachments and 3rd function are LandPride, and when in-line fuse is pulled out, the tractor functions perfectly.
