Power Steering line leak
jclitz
Highland Mi.
I have a 97 L3600 GST 4 X 4 tractor that has a leak at one of the lines to the front PS cylinder. The line incurred damage and IS leaking at the threaded fitting.
How much of a job is it to remove and replace a damaged line? Where is the best place to order a new line?
Thanks for ANY input/advice.
Michigan John
9,178
It's fairly easy to change the lines, just unscrew them, you should be able to get one made locally, if not you can order the parts online from places like Messick's or Coleman Equipment, or your local dealer.
