Poor man's logging winch
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
I installed a Superwinch 3500 in place of the backhoe bucket on my BX24. I need to tidy up the wiring but the winch works great. I set it up so everything except the battery wires and circuit breaker come off the tractor when the winch is not in use. I just use the remote to control the winch. I didn't use the ATV handlebar switch that comes with the winch for obvious reasons.
I built a wooden box for the solenoid and connections which mounts to the ROP. This comes off with 2 bolts. I will use the winch during the time of year I cut firewood. After that the bucket goes back. I used more connectors than I needed but I want the system to small parts for storage.
Our property is very steep and I need to get trees up to the road to process them for firewood. Decades ago I just cut trees into pieces and humped them up to the road. I have been backing the tractor up and pulling logs with hooks on the FEL bucket. This got too exciting when I would raise the bucket up to get a better angle.
Winch $179
Adapter for 2" receiver $75
Bxpanded 2" receiver replacing bucket $129
6 ga wire and miscellaneous connectors and crimper $45
I would rather have a Wallenstein FX35, but these cost $3000+.
WFM
L3800
Apr 5, 2013
1,342
671
Porter Maine
Well....you certainly did put in a lot of work building and wiring it.
I'm no expert, but it seems like if your winching a 12" log, you would be stressing the backhoe arm somewhat. If your winching like 6" logs then probley no issues. Generally the winch mounted close to the machine, I'm just not sure about out on the arm.
BAP
Dec 31, 2012
2,756
869
Be careful, that looks like a good way to flip your machine over onto yourself. Unlike logging winches, electric winches cannot quickly drop their load if something goes wrong.
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
Mostly I will be pulling a 10' length of a 10" alder. This may be a short lived experiment.
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
I don't have any experience with winches. I will keep this in mind.
5,577
A couple of things you could do for safety while experimenting is to keep your bucket full of dirt and keep it low. And, if room allows, leave your outriggers about 10" off the ground. That does not leave much room for any movement of your tractor.
NF6X
L3301HST w/ LA525 & BH77
Mar 19, 2017
106
Riverside, CA
www.nf6x.net
I thought that the electrical system capacity on these compact tractors is pretty small. Can it keep up with a big load like an electric winch? I would imagine that there would be a duty cycle limitation to let the smallish alternator recharge the battery after doing some winching.
coachgeo
Nov 16, 2012
2,460
35
Southern OH
suggested weight up front seems to be spot on for safety (full FEL bucket down low).
Another discussion on similar topic (trailer ball on B.hoe) suggested chains or?? from B.hoe bucket to rear of tractor to lessen stress on B.Hoe arms. Maybe two chains diagonal out to axle on each side or?
6,595
Logging winch has an A-frame built into the unit. The whole purpose is to lock the load and weight to the ground when winching in trees. It also helps keep the tractor from dragging backwards while winching.
Nice thing with your winch mounted to the back hoe. Drop your stabilizers while winching and keep the winch low. This will help keep you stability while winching the logs :)
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
307
259
catlettsburg, ky
As I look at your set:
I think you would have better results if it was mounted on the fel.
Your backhoe would be a good counter weight.
Mount your brackets inside on the bottom of your bucket. [emoji848]
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
The 6 ga wire comes right off the battery. The battery is a 26R small car battery. No problem drying my smoke test. We'll see what happens when I pull logs.
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
I already thought of the bucket of damp clay. I was going to put the outriggers on the ground. Maybe better to leave them close. I am going to align the tractor with the pull and use a snatch block if necessary.
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
Agreed. My wife won't let me buy a real logging winch.
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
Might be a good plan B.
6,595
We used to have one mounted to my dad's L2250. I believe it was made by Westondorf. But dont quote me on that. Winch was actually rated for a 50 hp tractor, but the price was right :D Used to use the snot out of it in the fall and winter. I've probably hauled close to 100 cord worth of logs with it, Plus another 30 or so log truck loads worth for pulp when I was in high school. They aren't too practical due to the cost for part time use. But when your serious and making a living off fire wood and pulp wood, they are worth there weight in gold :D Dad sold it to a buddy of his back in 94'. His buddy still had it as of 3 years ago and still uses it. Only thing that's been replaced/ repaired were the clutches, and it's on its second set. A good one is pretty much bullet proof and will out live and work you :D:D
Tooljunkie
May 13, 2014
4,150
Run it as you have it. Outriggers on ground. Bucket with ballast in it, also on ground. Those winches will pull 3500 rolling load on second layer of cable. So really overrated if anything. You will have no issues if you take care and keep loads low as possible. Freewheel cable out will save battery.
That hoe will lift rear of tractor, its way tougher than winch, keep that in mind if you start moving hoe with cable attatched to something.
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
Thanks, sound like good memories. I'm 75 so it's pretty hard for to make a business case for one. Maybe I will find a used one.
altoonapillarrock
BX24
Dec 29, 2012
20
Rosburg WA
Thanks, good advice.
