Pats quick hitch question
Chew
69
Centerville, Tx
Got my quick hitch installed and seems to be working well. Did have to install an extended top link.
Finally got around to using my big rhino brush hog and found that my 3 pt barely lifts it off the ground. I knew the angles would change some but my rear wheel on the rhino is barely off the ground (touches off and on over uneven terrain). Does this sound right or am I doing something wrong? I need to drive through a creek bed and the brush hog is gonna bottom out pretty bad because I can't lift it any higher.
What do you guys think?
CountryBumkin
Sep 27, 2015
568
Central FL
Is the problem a lack of hyd power, or just that the 3-point is fully up and still not lifting high enough for your hog?
What model tractor do you have?
Chew
69
Centerville, Tx
Hyd. power is good, I just raise up the 3 pt. all the way and it just doesn't lift it very high. Before the quick hitch, the brush hog was lifted very nicely with plenty of ground clearance.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Did you install the shims? If you did you may need more shim.
I don't know if this actually plays out but in theory if installed correctly the arc of the pin location should go from slightly lower to slightly higher than stock, but overall it shouldn't have much effect.
Also, the extra length means the top link has to be longer and that changes the geometry of the top link. Might want to try adjusting that.
Chew
69
Centerville, Tx
The old top link was a few inches too short. The new top link was adjusted out to the minimum to reach. I don't remember if I used shims or not but I think I did. What do they do that affects lift height? Sorry, pretty new at tractors. It's a l3400
"The realities are that, you know, as a black man, you know, Barack can get shot going to the gas station, you know." Michelle Obama
6,119
Which hole do you have the top link in on the tractor side?
If it's in the top hole drop it down a hole or two to get greater lift height.
Chew
69
Centerville, Tx
Well I did find a picture from recently. This is as high as I can get it:
And I found a pic from when I put a tool box on the back and confirmed that top link is in the top hole:
6,119
By looking at the top picture it also looks like you might have the top link set to long too.
See if you can shorten it up and still get the mower to sit right.
Chew
69
Centerville, Tx
Thanks. Will do
scdeerslayer
MX5200DT
May 23, 2016
434
SC
The shims in the Pat's Quick hitch account for various lift arm heights (as in top to bottom dimension, not height from ground). They go between the bottom of the lift arm and the inside bottom of the Pat's hitch in front of the arm ball and have a roll pin that you hammer into the shim. The roll pin then sits in a hole in the bottom of the Pat's hitch to keep the shims from falling out. I believe they come with 3 pairs of shims - 2 different thicknesses plus one with an angle on it. The instructions say to only use one shim on each side but I used both of the shims without the angle. If you don't have enough shim then the end of the Pat's hitch will hang lower than the arm ball.
Chew
69
Centerville, Tx
Got it lined out. Moved the top link down all the way and was able to shorten it up. Lifting up nicr and high now. Thanks for the info fellows.
Huskerfan
Kubota B2650 HSTC, Grasshopper 725Dt
May 24, 2016
64
Iowa
Has anyone tried Pat's QH with the kubota lower link telescoping arms?
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Yes, I have them on mine. If you call Pat's they will actually make hitches that replace the extendable end. They won't extend out, they just go in the same place so you're not making the arm longer, but with the Pat's you don't need the extendable function. I plan on getting some at some point before next spring.
jajiu
Jun 5, 2016
455
112
Rowley, Massachusetts
I replaced my HF QH with the Pat's and I went about 2 weeks. I just took the Pat's off and put the HF QH back on. The Pat's just didn't do it for me. I have had the HF QH on all my tractors (4 in all) and maybe I'm just use to it, but it works better for me. I'll put the Pat's on Craigslist and see if I can get most of my money back.
