parts for grey market tractors
The Chief
Kubota B7001 (grey market), RS1200 tiller, V1 FEL, Sears 16.5 hp garden tractor
Nov 6, 2010
Sundre, Alberta
Anyone know where I can get PTO gears for a B7001D Kubota tractor?
hodge
Nov 19, 2010
2,903
450
Love, VA
Try West Kentucky Tractor Parts (wktytpstore.com)- they have a lot of used parts, and may be able to help.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
You have a 7100. When dealing with a dealer tell them you have a 7100 and not a 7001.
Look up parts yourself online and go to them with part numbers............NOT the tractor.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
you need to be very , very careful when ordering parts for any jdm machine as they not allways the same as similar machines.
7001 and 7100 are very similar, but, not the same machine .
the rear axle/and geaboxes are very similar in a lot of respects but the inner parts can and do vary widely .
i have three 7001 rear ends and two 7100 rear end, only the two 7100 are the same , the 3 7001 all have differing parts from the 7100 and are not readily interchangable, i tried numerous combinations without success.
gear shaft vary as do gears etc.
Dont rush into this, do some ground work and source the right part if you can from a 7100, failing that, best option is to match the part visually if you dont have the correct part number.
I have been through all this parts issue matching jdm to other machines, its a bit of a minefeild to behonest and can easily cost you more in the long run.
hope you find the parts.
rob
Dale.p
B7000
Sep 27, 2013
Alberta
I'm looking for a bent rod for the clutch its connected to the clutch pedal and then to a spring acting as a pulley it keeps the clutch elevated and tensioned. for a Kubota b7000. or can anyone pm me the schematics for the clutch for a Kubota 7000.
