Parking question??
Kevinator
2010 BX 25
Jul 29, 2010
Northeast PA
Have a BX 25 and due to limited garage space I must park it with the bucket in the air resting on something..My question is will this hurt my machine being parked like this???
Bellinghamster
B7100 with FEL
Nov 25, 2009
55
Bellingham, WA
Other than the risk of it coming down and squishing something/someone, the hydraulic cylinder rods are exposed therefore subject to possible damage - dings, dirt, getting bent or rusting. (rust is unlikely unless they have inferior chrome plating)
Toyboy
BX2230D - RCK60-22BX - BX5450
May 18, 2010
649
971
Hayward Wi
If it's going to be garage kept, the short answer is no. Just make sure whatever you use will support it.
stuart
B7001 with loader & tiller, 3 point hitch and 4' rear blade
Aug 9, 2009
280
Aldergrove, BC, Canada
I agree with the earlier posts. The main thing is to find some way that the bucket (and 3-point implements) are supported, because the hydraulic pressure will bleed off eventually, and the bucket will come to rest on something.
Hollow steel tubing welded to an old tire rim makes an convenient support - stable when in place, easy to move around and very strong when in compression.
