Paint
kubota l 295 dt
kubota l295 dt loader, scraper
Dec 8, 2010
prunedale, ca.
Hi everyone, was wondering if any of you have used the Tisco brand paints in Kubota colors, I purchased in quarts and plan to spray on. i did noticed its a alkyd industrial enamel i know from other things i've painted it tends to fade and chalk after so many years. this paint was half the cost of Kubota akrylic paint i thought maybe i could use some paint gloss hardener in this paint to maybe make it last longer. was wondering if anyone has used this paint and what your thoughts were. Thanks Jeff!
LRP
202
canada
there is a product called nyalic. it ia a clear coat that has a viscosity
somewhere between water and olive oil. it can be brushed, roller, or sprayed.
it is uv cured and it will not yellow , peel and after it,s cured can be painted.
it can be applied on bare aluminum, painted surfaces, and superp on fiberglass. the downfall, it,s pricy.
Louis
kubota l 295 dt
Dec 8, 2010
prunedale, ca.
Thanks for info but that sounds like a top coat over this paint, I will probably be returning this for the kobota paint as Tisco must not be to popularplus i can always have a rattle can for touch ups.
