P0605 code, tractor bricked
captmikem
BX2660 MX 4800 and a bunch of attachments.
Mar 16, 2017
144
SW Washington State.
Had a battery fail, swapped it out and no start. 800 hours and few problems other than hyd leaks. Hard to load a dead tractor on a trailer without a tractor. But took it to the dealer to hopefully warranty replace the ECU and it won't happen again. Made them aware of TSB-2023-035-E-R1 will see what happens. Sure miss my tractor.
4,320
It still befuddles me that the simple act of changing a battery can 'brick' the tractor !
I'd love to know HOW the dealer installs batteries !!!! I'm assuming tractors aren't shipped with them in, if so, then HOW does the factory install ??
This is a SERIOUS request, seeing how many posts about 'dead battery,new battery, bricked tractor' there are here !
3,805
See post #27 in this thread: https://www.orangetractortalks.com/...code-after-battery-cable-failure.67622/page-2
miket1
Kubota L3901
May 10, 2024
10
17
Texas, Arkansas
Hate to hear that, let us know how it goes. I didnt know about this issue and my L3901 is out of warranty so Im sweating a little here
4,451
Crazy stuff!
My 2014 MB E-350 (gas) has TWO batteries!
One in engine compartment, and a smaller one in trunk.
To change either, I have connected a temp battery, BEFORE removing OEM for replacement.
Apparently, if not doing this,..... I am told, that it is a tow to the MB "stealer" , for their $$$$ new battery, and to have everything reset.
4,320
re: #27..
The sequence or order of how cables are installed is a SAFETY issue, nothing to do 'electrically'.
You remove the ground first, so that when you go to remove the +ve and the wrench slips and contact the frame, sparks and arcs don't appear,scare you, and you then need to find 4 more bandaids.....
captmikem
Mar 16, 2017
144
Picked up my tractor today, all it cost was the fuel to drive it there and back. Runs fine now. Really missed having it. I am lucky, my tractor is seven and half years old and the warrnty was extended to 8 years. I have to give a plus to the dealer, Dans Tractor in Battle Ground Wa. They have always done the best for me on my tractors.
