Overheating
Byron1100
BX2670
Dec 16, 2021
WrenbrookRetreat.com Australia
Hi, I run my BX2670 as a mower and slasher in hot weather >100F. It was overheating, I had a look at how the radiator was mounted and found the fuse box was stopping air flow on the right side. So I unbolted the fuse box and slung it close to the steering column wit zip ties, problem solved.
mikester
M59 TLB
Oct 21, 2017
3,549
2,010
www.divergentstuff.ca
You can also save money replacing fuses with pennies. Cheaper and last longer than stupid fuses that fail as soon as you put them in.
  • Dislike
3,316
Only real copper Wheat pennies. The current copper-wash-zinc pennies corrode and overheat just as bad as the ‘43 steel ones.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
Sarcasm aside, I think the point was the implementation of your fix. Do not trust the cable ties for long term retention of your fuse box. They tend to get old and brittle over time. Try to fashion some sort of permanent mount. Blocking a radiator's air flow is a poor design practice but you could engineer a better fix than cable ties.
2,965
Looks like you are new here. Welcome to a great forum.
Most people are helpful and your solution is a good pointer to others.
We are all may be guilty of sometime posting a smart a$$ reply (guilty myself). But best to take it in jest and move on...
lynnmor
B2601-1
May 3, 2021
1,444
1,159
Red Lion
I believe that is a rather small fuse box. Could you post a photo so we can see the blockage?
jyoutz
Jan 14, 2019
2,980
2,023
Edgewood, New Mexico
Stainless steel zip ties are the answer. Home Depot has them.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,807
1,523
WestTn/NoMs
I think Byron is trolling you guys that are dealing with snow control. Maybe you could send him some to put in his radiator 🥵.
