gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
In this thread a couple of statements caught my attention
http://www.orangetractortalks.com/forums/showthread.php?t=9529
So I wanted to ask directly about the Engine Heater, I haven't found the answer here or in the Manual..
My Tractor sits in a Pole Barn 24/7/365 it has cover but the barn is not heated..
Reading the manual says the the engine heater should be used at -4°F and below..
My question is, Will it harm anything to leave the heater plugged in all the time ???
I normally have to hit the road at 5:00 am to make sure it is clear for the Wife to head out to work by 8am. If I don't have the heater plugged in I would have to go out at 4:00 am plug it in the go back out at 5:00 am to fire up the tractor..
I also have access to a Thermo-Cube that only switches on at 0°F and switches off at 10°F
So what do you guys think, will it hurt the Heater or the tractor to keep it plugged in ???? use the cube??? or just get up earlier and deal with it when it gets cold ???
TIA for any respones
