Operating RPM
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
I have a L2501 and during general use like plowing snow, driveway maintenance and loader work I run the engine around 1800 RPM which seems to work fine. What rpms are theses tractors designed to operate at that is safe on the engine and gives peak performance
BX23-S,57 A-C D-14,
6,243
any RPM, should be 'safe' (as in engine won't blow up)...
as for 'peak performance', that'd depend on torque(power) you need, you'd have to see the engine 'RPM/HP' charts..'top of the mountain' is max HP vs RPM
edritchey
2026 Kubota T2290-48 2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75
Jul 19, 2014
1,179
938
Wellsville, PA
No emissions so just run 3 point pto driven at 540 and everything else wherever you feel comfortable with.
3,030
on your machine 1800 is pretty close to "540 pto rpm" thus a good place for torque and HP needs.
RalphVa
738
322
Charlottesville
On my last 2 tractors and will do on this one (2601), I don't need the 24-26 hp. So, I ran them at 450 rear PTO speed. and at 2/3 of that for FEL work.
JimmyJazz
1,273
805
Pittsburgh, Pa
Thats about where I run mine when moving snow, maybe a little higher for mowing. The machine will sort of tell you what's best. I think the feeling is that a little more RPM is better than too little.
nbryan
Jan 3, 2019
1,401
929
Hadashville, Manitoba, Canada
My front mount snow blower "runs" at 2500 rpm mid-pto so that's where I set it, with blower engaged at idle and not loaded, up throttle to 2400-2500 rpm then have at it.
Once the blower is biting into deep snow I'll push my speed until rpms drop about 100 rpm from loading and hold rpm there with hst speed adjustment.
I treat the rear pto implements the same, full operating rpms. 540 rpm for the chipper and rotary mower. That's 2300 rpm (plus something) on the engine, whatever, but I run the pto at 540, UNLOADED. Once under load the rear doesn't go below 500, unless overloaded.
When the backhoe is running I set engine at 2500 rpm, my B2650's "operating rpm" according to manual. Occasionally I'll throttle down some if there's exceedingly delicate or slow work needing doing with the BH77.
All other activities with the tractor are usually somewhere between 1600-2200 rpm, like while using loader or pallet forks, maneuvering a trailer, running the box scraper, getting around the yards.
On the gravel road without a load usually 2500 rpm in H gear, lets get there eh?
The only implement operated in low rpm is the 3-point post hole digger, barely above idle around 1350 engine rpm.
