OPC/Panel fuse blows when loading the bucket
De Food Plotter
B2650
Mar 12, 2024
Alvordton, Ohio
Has anyone else had the problem of the panel/OPC fuse (5amp) popping when loading the bucket from ground level to about a foot off the ground? No dealer I have talked with has any idea why this is happening.
Dustball
2016 B2650HSDC
Sep 15, 2023
389
246
Hudson, WI
Is this a smooth operation or are you jerky/haltingly bringing it up?
Reason for the question- if the tractor is bouncing, a safety switch may be moving around/being triggered.
If one of these safety switches is faulty and shorting out, that would blow your fuse. It may be a safety switch that you don't normally use and wouldn't notice otherwise such as the PTO switch or parking brake switch.
