Opc Fuse Blowing
Beavergreen
B26
Jun 17, 2022
Mills River, NC
I have a 2006 B26 that blows the OPC fuse. I bypassed the neutral saftey switch, the seat occupant switch and that leaves only the PTO safety switch. I have no idea where it is located. HELP!
Just so you know, by bypassing the 2 safety switches, I just wired the 2 wires together that enter both switches. Is that correct?
I think that the PTO safety switch is it because I was not having any problems till this spring after I rotovated my garden. Since I used the PTO, I’ve been having this issue.
Also, in browsing around in Messics website, I saw a OPC Controller. Being that it is $220, I want to be sure that I need it. Thoughts?
Thanks!
John
Mills River, NC
BX23-S,57 A-C D-14,
6,160
1st step is to get a good wiring diagram for your tractor !
Bypassing switches is not a great idea unless you KNOW where the wires go....
.'blowing' fuses is due to drawing too much current, typically a frayed wire' grounding' or a defective part.
No one an actually say 'it's this or that' without the diagram and some hands on diagnostics.
I had a look at kubotabooks and no manual for a 'B26', a few 4 digit ones though...
