W William Moore New member Equipment ZD221 zero turn Mar 29, 2022 1 0 1 Madison Ga Nov 21, 2022 #1 How do I check a temp switch and oil pressure switch 722D?
Dave_eng Well-known member Lifetime Member Equipment M7040, Nuffield 465 Oct 6, 2012 5,183 973 113 Williamstown Ontario Canada Nov 21, 2022 #2 These procedures are quite generic. The temp guage sensor changes resistance with temperature. You need a multimeter, even a cheap one. You could use a bicycle tire pump to test the oil pressure switch. The switch contacts should open at 7 psi Dave Last edited: Nov 21, 2022
