Oil leak
superduty7.3
Kubota l4400
Aug 13, 2023
Wv
I have an L4400 hst with 900 hrs that leaks oil from water release pin on clutch housing, sometimes it leaks and sometimes it doesn’t . I have read about some sort of missing or moving sleeve on propeller shaft to front axle. It’s been doing this for about 3 years now not a bad leak but I spent sooo much money for this machine I feel at the very least
It shouldn’t be leaking Kubota wants
$2000 to split it for a $ 20.00 seal ,I’m considering changing colors , any additional information would be greatly appreciated, thank you
2,581
This is similar problem - you may gain info on your tractor from this POST
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,866
2,914
Sounds like my Ford. $6000 in labor to seal the upper oil pan with a tube of ghetto gasket. Not even a real gasket!
