oil for m125x
Jd4230ps
M125x
Apr 29, 2019
9
Montague TX
Just bought m125x - 2008. Should i use sudt2. it has intelli-shift transmission. is sudt2 the best oil for older tractor?
SidecarFlip
Banned
558
Depends. If it's readily available Kubota hydraulic fluid (not oil btw, fluid) is fine but in lieu of that, any Kubota compatible fluid will work, preferrably synthetic for cold weather operation (if you live in a cold climate.
Myself, I use Chevron All Weather Synthetic in my M's., because my jobber is a Chevron dealer and it's readily available. With me, that is key.
Just bought another M and I'm about to change fluid and engine oil and all the filters, including both hydraulic filters, air cleaner filters (there are 2, inner and outer), oil and fuel filters. Because it's used, assume the previous owner was lax o maintenance so start fresh and at square one, change everything.
My 2 cents for what it's worth. I also presume from the size of the tractor it's not a 'hobby' tractor so just bite the bullet and do it. Grease it too if it has a loader and grease the axle pivot and the 3 point linkage.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I'd not sure what year they started using SUDT2 but it at least had SUDT for sure. I would at least use SUDT2 or better if it was mine.
