Oil filter
elnewfs
Bx1870
Jun 16, 2016
Colorado
I can't get the oil filter off. I can get the tool on, but can't turn it to tighten because everything is in the way, help, please
2,600
change the type of "wrench" or grip that you are using...........
did you remove the bonnet? Slide it forward?
there are dozens of type of "wrenches" , and if ALL else fails, the screwdriver works wonders..........
elnewfs
Bx1870
Jun 16, 2016
Colorado
The dealer we purchased the tractor from, sold us the wrench today, said it was correct. Guess I'll try the screwdriver. Is the "bonnet" over the current filter? Thanks!
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
Easiest way on a BX is with a cup socket (like a really big socket that fits over the end of the filter), a 3 plus inch socket extention, and rachet.
Dieselbob
BX 2230, LA211 loader, 60â€￾ MMM, 2â€￾ wheel spacers, grille guard, gauges, bucket e
Nov 17, 2014
197
Fort Wayne IN
This is what I use, but you must make sure you buy a filter that has the socket flats on it. Some don't.
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
Same I have drilled into filter and turn with screw driver more then once.
6,821
