Oil filter change on L2502
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
299
206
ottawa
I need to do my 50h service on the L2502. I've already changed the engine oil filter and the HST filter. I now need to change the "inlet filter" with I believe is the hydraulic filter.
I wanna know if that's gonna bleed a lot of oil. I'm planning on doing this in the field instead of the garage. Am I gonna need a large bucket and a gallon of new oil?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,277
1,899
WestTn/NoMs
If you just unscrew that filter you're going to drain way more than a gallon, unless you're mighty quick.
Option 1 Pull the plug, catch the oil (be prepared for 10 gallons), and reuse the oil.
Option 2 Use a Shop Vac on the fill port to maintain a vacuum on the sump and prevent the fluid from draining. I've never personally done this.
3,705
I did mine by just "being quick"...I lost a few quarts, but it was not too bad.....
However, if you "fumble" that filter, you will be sad.:cry:
