oil change MX 5100?
Ray Robbins
MX5100
Jul 8, 2012
Bardstown, Kentucky
I tried to change the engine oil in my tractor. Warmed motor 5 minutes.
Removed 228 oz. Oil, oil filter. Then installed new filter and 192 oz. Oil
Let the tractor sit 30min cheked and the oil was high on stick! Checked again
Same thing. I had to remove 64 oz to be right. i'm not sure the level before
The change. New Tractor, never added oil. Any thoughts? Thanks
Bluegill
Jan 11, 2012
1,560
Success Missouri
Did you run it after the change, to fill the filter?
I go by the dip stick, if it shows right, it is right.
kuboman
725
How hot was the oil?
How long did you let it drain?
Did you run it after refilling?
All contribute to how much drains out, and consequently how much you put back in.
Oil should be hot and allowed to drain till it stops dripping out the drain hole.
It should also be run after refilling to fill the oil filter.
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
27
Ventura Ca
Not sure about your tractor but my L3830 has 2 drain plugs, because the drive line for the 4wd runs underneath the oil pan so it sets kinda like a saddle over the drive shaft with a drain plug on either side, just saying stranger things have happened.......Dan
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
That's the same thing I was thinking.
Breeze
L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole.
Dec 24, 2010
149
Virgin Islands
Ditto!
That information is in the Operator Manual as well, if this the case with a MX5100. The wording says "remove drain plug" but the picture shows two of them, at least in my manual.....
