Hello I recently bought a 1976 L175. It has a 50" finish mower on the rear. The other day I hooked up the mower and everything worked fine . Lift went up and down no problem. I then went and mowed for about 1/2 hr and Then the lift would not go up to pick up the mower. I unhooked the mower and drove back to the garage stopped the tractor and started looking. Dont know whole bunch about it so didnt find anything obvious. The pervious owner said he never had any problems with the lift. The tractor set for over a year without being used before I got it. After the tractor set for a while when I started it the lift worked but when I went to get the mower it was not working so it seems to be something that happens when the tractor has been run for a little and gets warm, when first started works fine. Can anyone tell me what the problem could be? Maybe the fluid needs changed, how and where do you check the fluid?
Thanks
Thanks
