Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Greeting all
I recently purchased a nice B6000 to replace an ageing wheelhorse tractor that has been well and truly wornout now.
I found this site by luck today whilst searching for info on the B6000 tractor, and by all account, this seems to be an excellent source of info and help.
A few questions are needing answers too, if anyone can help it would be great.
1) how can you correctly indentify which year model of 6000 you have.
Its S/N is B6000-27874
also Has ZL600 stamped on a plate behind teh gear lever.
I've looked at a lot of pics and they do vary, mine has the fuel tank placed from left to right accross the chassis behind the engine with the battery located inbetween it and the dash/bulkhead.
2) is it possible to change the throttle setup , mine is a lever horizontally mounted just beneath the dash/bulhead. I see that some have a larger vertical lever closer to the steering wheel?
How much work is involved putting a floor mounted pedal ass as on 6100 and 7001/7100 models ?
The tractor is in great condition and the pto ccw issue is probably not an issue for me to be honest.
So there you go, nice to be on here and see you all.
cheers
rob
cheers
rob
