Newbie struggling with MX5200 OPC switch in the cold
NordTrac
MX5200, BH 92, LA1065
Jan 26, 2025
30
71
Quebec, Canada
Just got my 2020 MX5200 HST (520 hrs) with FEL (LA1065) and backhoe (BH92) on Friday (1/24). This is my first tractor, I rented B21/B26 a few times. Previous owner had the backhoe installed by the dealer and never took it off. The PTO and 3 PH have never been used. Got the dealer to add 2 hydraulic remotes to the back. Will probably install a 3rd function kit myself eventually.
Tractor is step 2 of the pre-retirement plan. First step was a metal roof on the (soon to be permanent home) log cabin on 50 acres up in central Quebec. The tractor will be mostly used for snow removal (300 m driveway), forest trail improvements (700 m to the river) and logging (about 10 000 spruce/pine plantation and 35 acres of natural forest to groom).
So, after the dealer delivered it late Friday, I spent about 30 minutes fooling around with it before I had to get back to work and wrap things up for the week. We don't yet have a heated garage for it and temperature was a frigid -24 C (-11 F) on Saturday morning. It started after plugging the block heater for 3 hours. I tried after 1 hours and then after 2 and got lucky after 3. After about 45 minutes using FEL to clear the driveway, it would not move anymore while hydraulics were still doing fine (it would start stalling when using the HST pedal). Came inside and came on this site for some clues. Became quickly evident that the OPC switch was to blame so, per advice from an older post, I took a blow torch and gently warmed the switch until the white lever would spring back up on its own again. Success!
Now, today with much milder conditions (-5 C, 23 F) same issue occurred 3 times. Actually, the first time it occurred, just heating up the switch casing did not fix the issue even with the lever springing back. After spending more time on OTT, my son (19) found a thread where it was suggested to add some thickness underneath the seat bracket to make sure contact was made. We taped about 1/4 in thick piece of wood un the underside of the bracket and it worked, for a while... I had to heat up the switch casing 2 more times before I gave up and parked the tractor.
The whole switch design is very bad and over complicated (aerospace engineer here). The simple seat contact switch on my Cub Cadet L1045 mower is much simpler and more robust.
I'm reluctant to bypass the OPC switch. Is there hope in getting a new switch installed as I suspect moisture got into the switch casing and will remain a persistent problem going forward?
Access to the OTT community's fantastic historical knowledge has kept us going over the weekend. It'll definitely remain my primary go to resource for all things orange!
Sorry for the long introduction...
Donystoy
Dec 10, 2013
661
299
Binbrook, Ontario
Welcome to the forum. Wondering if someone sprayed water in the area while washing the tractor prior to your purchase and inadvertently got water into the switch. Might have to remove it and try to get the water out with compressed air or whatever works. Have not looked at mine to see what style it is assuming that my 2022 LX2610 is the same.
8,636
Take a hair dryer and wd40 to it.
If your still having issues replace the switch.
NordTrac
Jan 26, 2025
30
71
Quebec, Canada
Good evening Donystoys,
It is most probably the case that when they pressure washing it, water got into the switch casing. The seller (aftermarket) tells me the casing can't be cracked open. I guess I'll have to bite the bullet and order a new OPC switch.
Many tanks for the feedback!
5,608
If water got it, WD-40 will, as well as low pressure compressed air.....
best to remove switch, warm up real good(hair dryer / heat gun), then spray WD-40, blow air into it, repeat 3-4 times, pressing plunger several times. Use beepin ohm meter to confirm/deny it works 100%.
you may need to remove the 'arm' as well as the rubber boot to gain access to the 'guts'.
NordTrac
Jan 26, 2025
30
71
Quebec, Canada
Good evening GreensvilleJay,
You got me thinking... If the switch casing (black box) can't be cracked open, perhaps I could drill a very small hole thru it, heat it up for a while to get the moisture out, spray a bit of WD-40 and then seal the hole.
I'd love to see the internals of the switch. Would not want to drill a hole and break something inside.
Thanks for the feedback!
8,636
The reason to heat it is not to get the moisture out, but to melt any ice in it.
Yea you can drill a small hole ( the size of the straw) and fill it with wd40, then let it drain out.
That will drive all the moisture out, and leave a residue on the contacts.
Then just use a dab of silicone to seal the hole back up.
NordTrac
Jan 26, 2025
30
71
Quebec, Canada
If you do drill a hole be real careful ! Don't push too hard, or you'll be buying a new $$$$ switch !
So, finally on Friday I got the opportunity to remove the OPC switch from the tractor, drill a small hole in the black casing and let it thaw and drain. The white arm was frozen in place. The switch casing must have been half full of water. I let it dry overnight and sprayed a bit of WD-40 inside.
I connected the switch back to the tractor connector without reinstalling it (by now the internal spring is probably broken and I'm getting continuity across relevant pins). Tractor starts fine and works for about 30 minutes before it starts stalling again. No matter what position I set the white lever to, it just wont make contact internally.
I gave up, cut the switch out and shorted the wires temporarily until I get a replacement switch. Tractor has been trouble free since then.
I was nice to operate the tractor for a while without any drama.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
779
677
E.
good on you for trying.
last OEM seat switch I replaced cost something like $20.
IMHO a cheap price to pay for no aggravation, peace of mind and a Kubota tractor you can trust more not to strand you before completing your chores.
cheers
