Newbie needs info
749
L2850 tractor
Jan 18, 2021
United Ststes
I recently purchased an older l2850 4x4. Runs perfect everything works as should, well maybe. The steering is my concern.
when moving the steering is easy. Steer it with a couple fingers. Sitting still (parked) on concrete driveway, you can not steer it. As soon As it moves steering is easy. Is this normal? I’m new to tractors and have no idea if this is normal or not. Thanks
5,201
normal as far as I see it. I've seen tractors with loaders front rims destroyed from turning while stopped. HUGE amount of stress.
think if YOU tried to twist your feet,in sneakers,while standing still,carrying a sack of concrete mix
749
L2850 tractor
Jan 18, 2021
United Ststes
Well good. I’m satisfied. Just wanted everything working as it should. It’s a great old tractor. It was well taken care of.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
527
Benton City, WA
Two wheel drive tractors tend not to have power steering. Four wheel drive tractors generally do. The simple cure is to not attempt to turn the wheels when sitting still. Be sure your front tires are adequately inflated. By the way, if your car has power steering and you're turning the wheels with the car stopped you are putting a lot of needless wear on your tires. Think of a pencil eraser in use on paper. They get smaller for the same reason.
749
L2850 tractor
Jan 18, 2021
United Ststes
All true. I was dipping a ditch out with the bucket in very very short quarters. Would have been so nice if the wheels would have turned while sitting still. But I agree on the wear and tear.
I’ve run big Cat endloaders. I guess I expected to much from my little tractor 😂
BobInSD
L5740
Jun 23, 2020
366
123
South Dakota
Two wheel drive tractors tend not to have power steering. Four wheel drive tractors generally do... [good advice snipped]
That has not been my experience. I have two 55 year old, two-wheel drive tractors with power steering. The last tractor I had without power steering was my (1950s?) IH Farmall M.
