New to me 2015 M5-111 rops with LA1854 loader, Awaiting delivery
Square_Root_Pharms
M5-111
Apr 21, 2021
32
Maine
I just scored a 2015 M5-111 for 25k online with about 2100 hours. I've been on the hunt for a tractor of this size for the last few months and finally pulled the trigger on one I like. Last month I almost bought a 2650 HD Massey Ferguson but I thought on it a little too long. I'm glad I did because I really had my heart set on a Kubota. The very first time I sat on a Kubota was when I was in Junior high in the early '90s I sat on my dad's friends little b series four-wheel drive and I got to drive it around his property. It was a little stick shift 4x4 and I remember that little thing went through some sh*t. I was always in awe of the ruggedness of that little thing. That summer I spent many hours on that little tractor mowing the guy's lawn with it.
Anyways back onto topic The tractor is still at the dealership I had them check the serial against any recalls and was told that they found that The DPF has not been fixed yet. Apparently it's supposed to get some sort of insulation around the DPF? What is some advice you folks can give me? I will also be having the dealership replace the two front tires. This is a used tractor so there is no warranty or anything. Once it gets delivered here I will buy a shop manual and probably fix it when it breaks on my own.
jimr63
M5-091HDC, L47TLB, L4701F, ZD1211-72, GR2120-54, RTV-X1140
Jun 24, 2015
120
47
SOMD
Nice tractor! Was there a loader question?
SDT
multiple and various
Apr 15, 2018
3,260
1,049
SE, IN
Insist that your dealer perform all "updates." Do not use the word "recalls" as there probably are none and doing so gives the dealer wiggle room. I believe that there were 2 or three updates to the M5, including DEF heater, etc.
SDT
Square_Root_Pharms
M5-111
Apr 21, 2021
32
Maine
SDT
ok just got off the phone again with them. the only updates for this tractor is the DEF header that is getting fixed. there is also another one that has to do with a PTO switch but it only gets replaced if the original fails.
