New old stock Rops
ShawnLimy
Kubota B6200D
Aug 10, 2023
11
Southwestern Ontario Canada
I lucked out on a Rops for a B6200
New old stock, that got lost in a warehouse somewhere.
All the bolts and spacers, pluse a new old stock seat belt. even instructions for both.
1,414
I suggest that you take the time to read through the instructions and then take the time to clean all of the threaded holes on the tractor that you need to use. Run a bolt into the hole fully at each location so you know the hole is clean. Then start the install.
Hopefully you will have a helper to lift the ROPS into place and to help hold it in place until you get a few bolts started. I suggest that you don’t tighten up any of the bolts until you get them all started well into the tractor.
