New (much needed) tool for greasing FEL....
Jeffroe601
2020 L3301 , FEL,Grapple,Grader Scraper,Box Blade,etc.
Feb 4, 2021
Philadelphia,MS
Hi all,
I have a L3301 with the LA525 Loader. I was having a problem with my grease gun getting stuck on the zerks on the forward pins by the bucket that are recessed. Kubota sells a lock-on type fitting that would eliminate this issue, however my dealer was out of them. So off to my local parts houses I go....I found out the hard way that the Lincoln brand will not fit in the recess to access the zerks and after returning it I found one at Auto Zone that does. It is made by Lumax and is only $22.99. The link is below if anyone has the same issue as me when it comes to greasing the recessed zerks. I have probably invented some 4-letter words fighting those pins when my grease gun would get stuck. Hope this helps someone......
3,316
When the nipple gets stuck onto a zerk, the way to disengage it is to twist the collar to loosen the grip.
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
you will find that many have switched to Lock-N-Lube or a product to similar that you found. Nice, simple, and easy to use.
nbryan
Jan 3, 2019
1,232
763
Hadashville, Manitoba, Canada
I finally figured out that a grease gun nozzle adjusts simply by twisting it. What a difference to discover that after decades of fighting with sticky or loose grease gun nozzles!
2,551
As Bmyers said - the LOCK-N-LUBE is the best 35 bucks you will ever spend!!!!
Only drawback is that it will get to those zerks buried in a hole that only allows the tip of a regular grease gun.
PaulR
Aug 3, 2020
579
459
Hadley, MA
I have a FB friend that works for lock n lube. Pretty small company based out of VT/NH afaik, so yea, I would recommend them on account of that...plus...their stuff seems to all get good reviews.
