New L3560 Battery
glennsorange
Buffalo,NY USA
Just took delivery last week on the new tractor. Battery was cranking slow, measured voltage both running and engine off at 11.56v. Over the course of several days, I had the same results. Today the voltage before starting was about 12.4 volts. While running it was 13.1v, shut it off, now it reads 12.6v. Is this normal for a new battery? Seems to be okay now... I’m not sure I feel warm and fuzzy being a brand new machine with 2 hours on it. Any thoughts on the subject would be appreciated. I never had a new battery act this way.
sheepfarmer
Nov 14, 2014
4,451
679
MidMichigan
Battery and tractor may have sat around for a while after the battery was activated. With only 2 hours on it, it may not have been run enough to keep it charged. Get a battery tender and put on it. Given that it's winter that will keep it ready to go when you need it.
rjcorazza
Mar 9, 2016
778
24
Hyattstown, MD
13.1v is not high enough for anything but a trickle charge. My L4060 ramps up the voltage when the rpms get over 1200 or so, otherwise I've seen as low as 12.8v at dead idle.
I would check the voltage again with the rpms at like 1500 and see if you read around 14.2-14.4.
glennsorange
Buffalo,NY USA
Appreciate the help guys! Just spoke with a tech from the dealer, they want me to watch it for a while, give it a little more time. They offered to stop out or even pick it up and bring it back to their shop if I wanted. I agreed to run it and keep an eye on it for now. It’s relatively warm out here this week so it may not be a good trial week, thought I better get it logged in with service. Next week we’re supposed to get much colder. Merry Christmas!
