So long story short I fell into a good deal on a New holland L555 with a Kubota V1902. When I bought it had fuel issues and was just bubbling out of the injection pump with the lines removed. So I figured I'd take apart the injection pump and check for debris/ contamination. I found it to be dirty and some debris on the inside. I cleaned it out and when priming the injection pump it now comes out maybe 3-4 inches nothing extreme. The engine doesn't start but wants to sometimes I can get it to rough idle with black/grey smoke for 15 seconds most times just turns over and wants to start with black smoke coming out the exhaust. The smoke is consistent and does it the whole time while cranking/idling. What I'm looking for is some possible insight on what to check and what to do to get it operating how it should? Also does anyone have a source for a full rebuild on the injection pump or a parts breakdown diagram? Any help or advice is greatly appreciated.
Some questions that might arise:
Yes, the injection pump was timed and put back correctly with the slide and timing marks.
Yes, I tried a new fuel source.
Yes, all injector lines and supply lines were blown thru.
