New engine advise
Floridaman
12
Florida
Hey folks! I currently operate a pressure washing business in Florida. These 40 hp Kohler and Vanguard engines are not getting any cheaper and they only last a few years. Right now you can pick one up for $3-4k, and I’m limited to roughly a 15gpm pump at 2400 psi.
I am eyeballing some Kubota engines, more specifically the V2403 and V3800. Little did I know these little engines are regulated by the EPA just like the new diesel trucks. So all the emissions from the trucks carry on to these tiny engines.
The issue I think I am going to run into is the engine might be on for 20 minutes here, 30 minutes there maybe 10 minutes here, 60 there etc. I know this will cause issues with the DPF filter just like it would in the truck.
I did find an engine that would fit my needs, but unfortunately it’s located overseas and I don’t think customs is going to give it the stamp of approval since it’s a 2024 model, but it has no emissions.
Based on my needs, do you guys know of any options that might suit me?
pictures below is the engine I’m looking at, but like I said above, I’m not sure if customs will allow this into the US lol.
lynnmor
B2601-1
May 3, 2021
1,751
1,555
Red Lion
Would it make sense to switch to an automobile gasoline engine, such as GM "Iron Duke" 4 cylinder engines? It would eliminate the short run issue of diesel but possibly increase fuel consumption.
Firefight100
MX5200
Apr 3, 2021
108
81
63379 troy mo
you will need all the ecu's and harnesses that go with it to run. Try to find an older engine wo electronic fuel injection. Normally less than 30 hp does not have emissions electronics. Also keep an eye out for a rv generator. They are usually cheap and the come in diesel versions also.
Floridaman
12
Florida
I have not thought about that. How big is the iron duke?
Floridaman
12
Florida
Is 40hp the range you need to be in?
im trying to get into the 60 hp range.
the formula we use to match the pump to a engine is PSI x GPM / 1450 x 1.5 = HP needed. Some folks use a 1.3 number, but I feel it tax’s the engine to much.
Floridaman
12
Florida
ecu’s and harnesses? Im sorry, but what are those for? All ive ever used is gas. Add fuel and a battery and crank it up. I know diesel is a whole different ball game. I need to stay in the 60hp range. When I did ask the seller if this engine was ready to be used, he told me yes but obviously I have to take that with a grain of salt.
6,750
ecu’s and harnesses? Im sorry, but what are those for? All ive ever used is gas. Add fuel and a battery and crank it up. I know diesel is a whole different ball game. When I did ask the seller if this engine was ready to be used, he told me yes but obviously I have to take that with a grain of salt.
You are looking at a direct injectjon common rail engine. Gas or diesel those type engines require sophisticated computer engine management = ECU and a whole bunch of sensors.
10,491
A V2203 is a very common non emissions engine the requires no computer.
Granted it's only in the 45HP to 51HP depending on the submodel.
Diesel engines can normally drive larger equipment due to higher torque.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,645
2,226
WestTn/NoMs
What RPM do you need? Is it variable speed, automatic idle, or? Is this a one-off or multiples?
I'm thinking you might luck into a wreck with a good engine w/accessories.
Floridaman
12
Florida
rpm doesnt matter as it’ll have a poly chain on it and I’ll use sprockets to get the pump at the right rpm, either 1450 or 1750. Just need one for myself.
lynnmor
B2601-1
May 3, 2021
1,751
1,555
Red Lion
There is plenty of information online about cubic inch, horsepower and availability. Be aware that there are several 4 cylinder engines that folks have been calling "iron duke" and they are entirely different. The Pontiac version is regarded as the best, they were used in a number of brands including Jeep.
SDT
Apr 15, 2018
3,573
1,319
2.5 L.
Not sure if it is still made. It has not been used in cars for decades but might still be used in boats, etc.
FWIW, My 2025 30KW Kohler genset uses a GM derived 2.2L turbocharged NG/Propane . The short block is GM and the cylinder head, etc., is made by (for) Kohler (now Rehlko).
Kohler/Rehlko makes other gensets using GM derived engines.
SDT
Apr 15, 2018
3,573
1,319
Yes, and they are EXPENSIVE.
SDT
Apr 15, 2018
3,573
1,319
Such nonsense is used to comply with governmental emissions regulations.
Firefight100
MX5200
Apr 3, 2021
108
81
63379 troy mo
The engine control units are mounted on the vehicle, tractor, bobcat, ect. The engine would be good to go if you are replacing an engine in one of those. But to use as a standalone engine? You will be missing a ton of electronics and they are very expensive. You need to fine an engine that doesn't have electronic injection. These are called "Mechanical engines" because of the lack of electronics.
6,750
The raw performance gains that come with common rail direct injection (gas or diesel) are quite substantial. You could completely eliminate emissions requirements and OEMs would still be designing and building engines using common rail direct injection, computerized engine management, and the panoply of sensors needed to make it work. Mechanical injection is as dead as carburetion.
SDT
Apr 15, 2018
3,573
1,319
In that case, why not just find a suitable sma
High pressure common rail injection is one thing DPFs and DEF, quite another.
Absent government regulations, methinks that manufacturers would design and build diesel engines (and just about everything else) according to market demands. Such has been the case for decades, indeed, centuries. Some engines would have expensive common rail injection while others would not. Few, if any, would have DPFs and none would require DEF. Indeed, engines that are below the mandated emissions HP limit still do not have expensive common rail fuel injection, engine controllers, DPFs, DEF, and other such nonsense. Methinks such will remain the case until government forces change directly or indirectly.
