New BX Series - BX**90
Sidekick
Jul 29, 2023
1,295
1,893
N.Y,
I see they have the auto throttle available on it now.
Daveinwestmi
L3560 ROPS, BX2380
Jul 6, 2019
14
Kalamazoo, MI
Doing away with treadle pedal, nope I'll keep my 80 even though it's got lots of hours. Having a Grand L my muscle memory can't adapt at my age.
whitetiger
Nov 20, 2011
3,807
2,205
Kansas City, KS
The electric over hydraulic push button clutch on the PTO allows deleting a manual clutch from the driveline.
The BX series tractors have never had a clutch pedal.
js312
BX1880, LA344S, 48" MMM
Jan 28, 2024
55
35
New England
They moved the hydraulic connection higher. Like that. Have yet to remove my FEL for fear of leaking when putting it back on. Pedals wouldn't bother me from my 1880. Hate to see what they want for these. Probably twice as much. I'll stick with what I have for now.
Mine was fixed by the dealer under warranty once even though it should have been new enough to have the version that doesn't leak. I haven't removed it since, I just pull the bucket off to mow. Aligning mine so it'll drop in properly can also be tricky, even on level concrete, and it looks like they revised the cradle to prevent that issue.
It is nice that it can come with the larger R14T tires from the factory - I plan to buy them for mine at some point. Factory LED headlights is also a plus - I put LED bulbs in mine, though I also have the factory ROPS lights which were already LED.
I had an x series John Deere with the side-by-side pedals and now the Kubota with the front/back. I really don't think I have a preference and the Kubota pedal setup wasn't really a learning curve and didn't have me missing the Deere setup.
It's fairly unlikely that I'd swap for the 90 series in the future. Truthfully, I bought the BX to try to get down to one machine for everything and it succeeds, but I sometimes wish it wasn't as cumbersome to mow with. I didn't want an x700 at the time because it was similar money with no loader. I think the ideal would eventually be an AWD Diesel x700 series to mow and snowblow with, then keep the Kubota for loader work or to pull things with.
Shawn T. W
Dec 9, 2024
871
1,580
SW Missouri Ozarks
Wondering if the increased HP on the Premium model is due to the common rail fuel injection? Or do they just rev at higher RPM?
The other models seem to still have the direct injection, so no computer on those ...
PaulL
B2601, MX5200.
Jul 17, 2017
2,812
1,803
NZ
Typically they like all the models to have the same RPM, as the hydraulic pumps, mowers etc are set up for that speed. I'd guess the common rail would add a few HP, and probably make it run cleaner too.
Shawn T. W
Dec 9, 2024
871
1,580
SW Missouri Ozarks
That's interesting, I didn't know that ...
Massey Ferguson & John Deere increase the RPM, and use the same engine in both the 23 HP & 25 HP versions ...
Here it shows that they use different displacement for the different HP ... These are the "old" 80 series ...
Kennyd4110
Vendor Member
Sep 7, 2013
1,529
913
Westminster, MD
www.boltonhooks.com
We are the the EQUIP EXPO in Louisville KY this week, sadly the new BX 90 series is not here on display, they said it will be at the National Farm Machinery Show in February of '27.
PaulL
B2601, MX5200.
Jul 17, 2017
2,812
1,803
NZ
Correct. I once upon a time did a table of all the then current small Kubota models: https://www.orangetractortalks.com/forums/threads/bx-vs-b01-vs-b50.36719/
I had assumed the new 90 series must have had higher power than the old 26hp model. But thinking about it, of course they can't. 26hp is an emissions threshold, going over 26hp typically requires addition of a DPF.
