Neutral Switch Keeps me from starting
us237841
L3010
Aug 21, 2010
Piedmont, SC
:mad:I am tired of my kubota L3010 HST not cranking because one of the switches has not been made.
The one for setting to neutral is the one that gives me fits. I am considering bypassing it.
Does anybody have any suggestions?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Not that I'm telling you to modify a safety feature but if I was going to do it I would suggest using one of those wire splicers that fit over two wires and you push the little metal blade thru the insulation with a pair of pliers. The blue ones easily fit over the 2 wires going and coming from the safety switch and joint them together therefore by passing the switch. Tape it up good and problem solved. The benefit of this method is that no wires need to be cut and the splicers can be removed with almost no damage to the wire other than the small cut in the insulation which can easily be taped up. My high/low shifter had a switch in the neutral position that gave me a fit. It works every time now.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Yes! Don't,its there for safety .You may forget its disconnected or you may fall ill or have an accident and another person may start it in gear.
Dave
kuboman
725
Dave
I think I agree with that one. That is one switch that should not be bypassed. Spend the bucks and replace it.:eek:
