Need help with joystick on m7060 fel
Jacdelivery
M7060 m26 loader
Dec 22, 2017
First off this is my first tractor that I just inherited. I know nothing about these things. Learning as I go. So here the problem, joystick seemed really weird lately (a lot of play) so anyways parked it yesterday and now the loader will not go down. So I took cover off joystick and seems like cable goes all the way in but loader doesn’t go down. And the stationary ball thingy in back broken white plastic on ball. Fell right out. So I was screwing with the cable and was going to pull out of housing and when I loosened the set screw a chunk plastic housing broke off with it. So basically need whole new joystick and a cable I think. Problem is I can’t find any info on this one or a part number.
9,749
In order to help you, we need the loader model # including the last letter, serial # too would be helpful.
And does it have 3 cables (self leveling) from the lever or 2 cables (standard)?
mbu
260
United States
Typically the FEL for the M7060 is the LA1154. But regardless, here's how to find the parts...
If you have a Kubota loader, go to Kubotausa.com and click on parts. Then click on illustrated parts list; agree to user agreement; then type in LA1154 as the model or what model you actually have.
Since you're in Canada, I don't know of a dealer that will show their cost. However, if you write down the part numbers and go to Messicks.com and do a search they will show the retail price in U.S. dollars.
7,116
The Canada version of the parts diagrams are at:
https://kubota.ca/en/parts-services/parts-catalogue
Like Wolfman said, you'll need the loader's model #, and put in the model search to get at parts lists/diagrams as mbu described.
And post your loader information here as well. There are some pretty smart guys that can help you through it.
Jacdelivery
M7060 m26 loader
Dec 22, 2017
Ok so it has a big sticker says M26 on the loader arm. But if that’s not the model number then I’ll look for it and a serial number tomorrow. And the joystick only has 2 cables.
9,749
The M26 Loaders are only used on the Canadian models. :(
From the US I can not get any information on the loader controls that they have use for that loader.
If you go to the Canadian site it might get you to the diagrams you need in order to order the right parts. ;)
