I need some help looking for a part for my L295DT. I installed a loader and would like to install an auxiliary pump off the front of the crank, I have seen several with this application, my question is where can I find the coupler from the crank to the pump?? I found a shop that can make one but there must be one out there somewhere?? The ones I've seen look factory (they all look alike). If I have one made,I need to know what size the spline is on the front of the crank. I put a mic on it and it looks like its 25mm,21 tooth male spline, is this correct?? Anything would be helpful...thanks
