2017 L3301 434hrs on aftermarket hour meter
I have the engine warning light on (red circle with ! inside)
will not operate under load. in low gear it stalls out as if I'm in high gear trying to go up hill.
hydraulics are weak too, wont even lift itself up.I have already replaced fuel filter and water separator
is there anyway to pull (and eventually erase) codes without spending the $2k for a semi proprietary scan tool?
nearest service center is 2.5hours away. if they were closer I would just run down there and get a diag.
Today I plan on:
New battery (unrelated but was needed)
Take off and clean DPF
test hydro pressure
also being past the 400hr mark and going to drain hydraulic fluid and replace filters. ( I know should have done sooner)
retest hydro pressure
look for obvious issues.
Today I plan on:
test hydro pressure
