My L4740 with 180hrs has a problem, the PTO runs all the time, it will stop with the clutch. I split the tractor, removed the clutch pack, two disc are welded solid together,and there are a few others worn paper thin, I can see marks indicating heat. The only PTO attachment I have is a three point spreader I use when plowing snow. I've order replacement parts. my question, is this a common problem, any idea why this happened. I don't run the spreader at PTO speed because it throw's the cinders to far.
