My BX2200 won't start
orantractor
10
lombard
My BX2200 won't start. I can hear the clicking sound but nothing happens when the key is turned to start. I measure the battery and it is about 12.5V. When clicking, the voltage drops to about 10V. But it is 2-3V when turning to start. Is the battery should be that low (2-3V) when start? Please advise. Many thanks.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Bad battery most likely, bad battery cables/connections 2nd.
thepumpguysc
267
Sunny South Carolina
Think of it this way>> you have a 12v system.. if you only have 2-3volts to the starter, which requires 12v to work, do u think its gonna spin it?
Try to "jump off" your tractor w/ your car using jumper cables.. or if u have a battery charger, use that & put it on "start" of a few seconds & try it, if it starts, u got a dead cell in your battery.
See post # 2...
Adam G
BX22 (Sold) B2920, LA364, BH65 w/Thumb, RCK60, Woods 5000 chipper, Bush Hog rear
Apr 1, 2018
35
Upstate NY
check your connections including grounds
