Wanted to know "which" AG tires to get w/new MX5800 4WD w/FEL.? Options are only for the Rear tires - as the Front AG tires always = R1 9.5 - 16 "Dura Torque 6 stud (per Kubota website).
REAR tire options are:
> R1. 14.9 - 26 Titian Hi Power....or > R1 13.6 - 28. Titian Hi Traction LugTL...
I will use tractor to til/disc/plant 6-8 acres of fields and "mud" is a regular condition in some areas. Will also use FEL to move occasional dirt, gravel for driveway maintenance, and remove rocks etc. from fields. One Dealer recommends the smaller diameter but wider 14.9 - 26 for "stability" w/FEL. Another Dealer suggests 13.6 - 28 for "best traction".
My thoughts (or guess) is either would work fine and leaning towards the 14.9-26 "thinking" slight traction loss off set by a little less "sinking in mud" w/fatter tire, a little more stable "side hilling" (although only a few "slight" side hill areas I would be driving). Likely over thinking this whole tire thing but that's what these forums are for - any other thoughts/opinions appreciated.
