Using the bottom most holes (of 2) on a MX5200 on level ground what is the range of motion of the lift arms (to the center of the arm hole) and how high/low shoud it go.
Should your arms be able to drop below 12" for dirt work?
Should they be able to go higher then 25"?
I can't find PTO movement specifications (other the max weight) for any Kubota.
