I am NO kind of hydraulics guy!!!
The previous owner damaged and badly repaired the loader mounts. I had to remove the 3 hydraulic lines to do proper repairs. Unfortunately, the lines did not have any quick disconnects (Q/D). I removed the 3 lines to remove and repair the mounts and had Q/D's installed. Unfortunately, I failed to mark which line's went to which location. There are no markings on the distribution block or control valve. I connected the lines and tried the joystick. I immediately developed a spraying leak where the joystick goes into the control valve (pic 1). I have 2 questions. #1 which line goes where ( I marked one line with red tape and one with yellow the other I left with no markings. #2 How do I repair the leak? Is it possible that, when I get the 3 lines running to the right places that the leak will stop on its own?
