I have an MX5100 (4wd, gear drive, FEL, fluid filled rear tires), and I am gearing up to use it to bush hog property in Southern VA. Most of what I will be cutting is property that was timbered about 15 years ago. No stumps or major rock croppings, BUT it is not smooth pasture, it has slopes, healthy ditches, and hills. Will be cutting through 6 months of growth that will include thickets, bushes, pine sapplings, and grass.
I am looking for a rotary cutter that can handle this ~25acres of grass and saplings. I previously bush hogged this property with a Mahindra 2555 (~4300lbs machine, 4wd, hydro, and a FEL). The machine was rated at 42hp at the PTO and it seemed to struggle on some grades and with thicker saplings. The rotary cutter was a Kodiak MD 6' unit. This tractor never felt unstable with the weight on the back end, but it defintely struggled at times with power output. I am not sure if this is a limitation of physics or of Mahindra marketing (i.e. lower PTO output than advertised) OR if the hydro would just overheat and everything would slow down....I never got any warnings, but it would seem like parking the tractor for 45 mins. would solve this issue (for a while).
I am looking at Woods Brushbulls and Bush hog 286/296 units that are for sale locally. Most of these units are rated at 45hp PTO minimum and 1100~1200lbs. The MX5100 is rated for 44hp PTO and the manual states a 1000lbs max. for rotary cutters. I prefer to run more HD impliments when possible, is this too ragged edge or was Kubota overly conservative? I don't mind running slower through heavy brush, or running smaller cut paths, but I don't want to be right at the limit of the tractor for the sake of a deal on a HD bush hog.
Thoughts, opinions?
Thoughts, opinions?
