Musk Thistle Control?
LarryBud
L3130
Dec 5, 2020
255
134
Cleveland, MO
Hi Folks,
I have a few acres which were worked with a dozer last year. I have replanted some, with more planting to be done this fall. The dirt work has created a serious musk thistle outbreak.
I have been mowing to prevent them from going to seed. I'm sure a few will seed as they lay flat under the mower deck. Now comes spraying. Questions:
If I spray now, as the heat of summer approaches, will it be worth the time and expense? Or, do I keep them mowed and go after them this fall / next spring?
Also, I can use 2, 4, D for about $50 / 2.5 gallons or the county agent suggested Grazon Next HL for ~ $150 / 2 gallons. Since my labor cost will be the same while spraying either, I want to use what effective but I see 2, 4, D is the primary product in Grazon.
Anyone have experience / advice here?
Thanks
7,677
jyoutz
Jan 14, 2019
3,626
2,719
Edgewood, New Mexico
Hi Folks,
Thanks
Mow to keep from going to seed. Use a 2-4-D product to kill plants, and seed grass to thicken the competition. Ask the county agent about the differences in herbicide products. Often a branded product will use additives to make a basic herbicide more effective for certain uses. I believe that musk thistle is sensitive to plain 2-4-D, but do a little research.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
687
754
Indiana
Glyphosate, 24-D, and triclypr all kill thistles.
I spray Canadian thistles with whatever is in my pump sprayer as I spot spray other weeds and briers. 24-D is best for a hay field as it won't kill grasses or clover. 24-D is the most toxic, so follow the safety instructions.
